SC Crank '49
GA. Kern
10-27-2002 14:01:22
I'm thinking about making a crank for my SC. (can these be purchased?) I haven't taken the radiator off, so it's hard to see what I have there for a crank to connect to. It looks like it is a stub of a shaft going through the housing. On the crankshaft pulley end, it has the pin through the shaft for gripping the slot. On the other end, for what I can visually make out,--just looks like a plain stub of a shaft (no pin through the shaft on that end) What is it supposed to look like? Have not seen this crank since I was a kid and don't remember what it looked like on the business end. Comments appreciated.
Mike Schotte
10-27-2002 16:28:35
 Re: SC Crank '49 in reply to GA. Kern, 10-27-2002 14:01:22
Hello again Gerald,
I made a drawing of my SC crank for someone on this board about a year ago. I never heard whether they built one or not.
I'm sure it's easier to buy one from a salvage yard, but I can send you a full sized plot of this drawing to use as a template if you would like.
The link is to a photo of the drawing at my SC website... which has still not improved any, I'm afraid to say, even though I now have 10 CD-roms full of tractor photos!)
-Schotte
GA. Kern
10-28-2002 18:06:21
 Re: Re: SC Crank '49 in reply to Mike Schotte, 10-27-2002 16:28:35
On the shaft with the spring--the crank end is just a blunt shaft with no female receiver. Somebody did somthing to it. Guess I can make a receiver and weld it on the shaft.
Would like the Crank drawing if you can send it. I'll give you my address in an e-mail.
Mike Schotte
10-28-2002 18:27:14
 Re: Re: Re: SC Crank '49 in reply to GA. Kern, 10-28-2002 18:06:21
Gerald,
According to my S-series parts manual, the part you are missing is #5636A "Joint". It is held onto the shaft with a 5/16" X 1-3/4" long 5-groove pin.
I'm betting your pin sheared off and your joint fell out. With any luck, you will find it inside a pile of muck and leaves inside your front end casting. (it's amazing how much stuff can stay in there!)
Good luck,
-Mike
GA. Kern
10-28-2002 22:43:39
 Re: Re: Re: Re: SC Crank '49 in reply to Mike Schotte, 10-28-2002 18:27:14
Mike you are amazing! It is as you said laying in the partition under the radiator. Won't come out through the hole in bottom of housing so will have to take off radiator. I had to go out and check it as soon as I read your comments--it's 12:30 am. One less part to buy, that's good news.
Regards, Gerald
GA. Kern
10-28-2002 22:43:23
Regards, Gerald
Jason
10-29-2002 09:21:35
 Re: Re: Re: Re: Re: SC Crank '49 in reply to GA. Kern, 10-28-2002 22:43:23
Gerald- I just removed the radiator on my 43 SC for repairing a leak and just so you know- the hollow cavity that your part is laying in is not any more accessible from under the radiator. You'll have to work the part out through one of those other holes in the casting.
If you end up removing the whole shaft assembly that the crank "plugs" into, then removing the radiator will be necessay- just be prepared to drive out several old rusty shear pins...
Good luck
