Case diesel injection systems
whitedvm
10-24-2002 07:23:45
Can anyone explain to me the difference or the advantage/disavantages between the case Powrcell
and the case Dynoclonic direct injection systems
for diesel engines?
thanks
hunter
10-24-2002 16:16:16
 Re: Case diesel injection systems in reply to whitedvm, 10-24-2002 07:23:45
Case's first diesel the 500 - 6 cyl 377 used
the lanova system - It is a power cell use to
provide a smoother running - less knocking -
engine - It's draw back is that heat remains
in the power cell - thereby wasting energy.
Others that used the powercell were Allis Chalmers in the d-17 & d19 diesels. Case use
this system (power cell) through the 730-830-
930-1030-1200 series tractors. Many felt is
provide more power as the tractor lost RPM's
under load. Well they just did not knock - like
the open combustion chamber diesels as they lost
RPM's under increasing load. With the start of
the 70 series tractors Case went to the open
combustion chamber tractors completely - having
first started the open combustion chamber in the
188 cu. in. diesels that were put into 430-530-630
models as well as their backhoe tractors. It is
interesting to note that the first case crawlers
and little diesel's put into the 300 - where of a
manufacture that use the lanova system. I cannot
remember whether they were all continential's or
not. The terra track was quite a machine. Way ahead of it's time. There might have been a waukasha(spelling?) there some place in this mix -
but they were lanova's too. O'ya the first Mpls
moline's, Oliver's & Massey's were power cell too. JohnDeere and IHC used open combustion chambers - but they first started on gasoline in IHC's case or had a pony like Cat to start them in Deere's case.
I assume that the lanova system was an easier
starting diesel. With a little either - the case
power cell would start at very low temps - but
then it helped to have put some number 1 in the
tank to keep lines from freezing/gumming up.
With a large propane torch and a little plastic
covering you could start them in most any temperature without either. The first diesels
had an either ejector - with either capsules for
cold weather starting - they also had a decompessor to lock the valves open to turn
engine in tough conditions. That way you could
clean out the unburned fuel and give it another
try.
best,
bill koob
