What Model/Year Case Tractor Have I Bought
Randall Myrick
10-23-2002 10:52:34
this past weekend, I bought a tricycle front end Case Tractor. 4 cylinder, gas, Eagle Point hitches, 4 speed, and on the gearshift it reads VC 131 if that helps. Faded two tone paint with sort of yellow on hood and Case orange on the rest. Push button start switch, push/pull kill switch, has been converted to 12 volt. Has spin on oil filter. Throttle is both lever under gauges but then a foot throttle as well.
Never having had a Case tractor before now, I want to tune it up but have no idea what Model and Year it is. Any held would be appreciated. Thanks in advance.
hunter
10-24-2002 16:31:53
 Re: What Model/Year Case Tractor Have I Bought in reply to Randall Myrick, 10-23-2002 10:52:34
I cannot remember for sure - but think the eagle
hitch started in 49 - Your tractor sounds like
at least a 1949 or later model - No chicken
roost for steering - right? - believe the 13 is
the clue.
Link
clint
10-23-2002 17:39:25
What is the number on the plate located on the dash panel? If you don't have one my guess is a late model VAC. 1951-1955. The paint is probably wrong. It should be all Flambeau Red. If you have the serial number take 4 off of the first two digits and that will be the year. My 2cents...
jal-SD
10-23-2002 13:45:08
Take a look @ tractor photos section on the left. Look under Case, you'll probably find a picture of one. Sounds like it might be an early number series or a V, S or D series that was painted like the number series. (My $0.02 worth. jal-SD)
