Slobbering
Paul Lamb
10-21-2002 20:59:29
1955 Case 400 dsl.I have slobbering out of the exhaust manifold.I have been told this is common messy but not serious.The same person said to hook up to a plow and work the dog out of the tractor.Anyone have other advice.Tractor runs good otherwise.I know I'll get the right answer!
Max
10-23-2002 20:39:28
 Re: Slobbering in reply to Paul Lamb, 10-21-2002 20:59:29
Try not to idle it to much. What could be happening is that when diesels idle to much or not hard enough, the older injectors dribble to much fuel out thus washing down the cylinder walls. When I was in a shop we used to cure this problem by putting them on a dyno for about fifteen minutes under full load. Its amazing how clean a diesel engine is around the valve when they are worked near their output power on a consistant basis.
Larry M.
10-22-2002 20:55:40
I have an International 986 that does that sometimes too. I just hook it up to the plow or the disk and work the tar out of it. It usually stops it for a couple of months. It doesn't seem to matter what time of year it is,or how warm or cold the weather is.
Paul Lamb
10-22-2002 16:39:54
Thanks for the answers.To Larry No cold here yet.Coolest yet has been mid fifties.To Ron no water in oil,does not seem to be using oil.It may have fuel in oil will check.I have been told to work it as hard as I can most of a day.
Larry
10-21-2002 22:41:39
I'm wondering if you might have #2 diesel in it and the weather is cold where you are at? I've seen diesels get a case of the slobbers in the winter with the #2 diesel fuel. If that's the case try running it on #1 and see what happens.
Ron
10-21-2002 21:31:02
I just fixed my 900 from doing the same thing. In my case, the tractor had not been started for many years and it had a stuck valve and it was actually slobbering out the exhaust pipe. If your tractor is running smooth it could be oil around the rings. Is it using oil? Some say you can work the tar out of them wide open for about two hours and the ring will seat back, if in fact it is caused by the rings. Also, a leak in a head gasket will cause them to blow water droplets out the pipe. You would probably have some water in the bottom of your oil pan if this was happening.
