Weights
Richard E. Hey
10-16-2002 18:37:34
Doing a little cleanup and found these two items. They appear to be weights of some sort. They are about 30 inches long, 3.5 inches thick, 8 inches wide. They are slightly curved. The ends appear to be somewhat beveled. In the middle is stamped J.H. Case, No.10. They appear to be made of brick like material, weighing about 30 to 40 pounds. Could someone please tell me what I have got here. Thanks Richard
Tom in Mo.
10-17-2002 17:57:25
 Re: weights in reply to Richard E. Heyduk, 10-16-2002 18:37:34
If they are fire brick material, you may have something special. Cast iron will be substantially heavier. If they are real heavy, they are probably cast iron with maybe a little filler material. Cast iron would be a front weight. The dimensions you describe in cast iron would be nearly 100 lbs.
klyde
10-17-2002 04:43:33
firebrick from a steamer???
Richard
10-16-2002 19:18:59
Boat anchors?? Naw! we use them kind of weights for our fishing poles out here in SD.
fcn
10-16-2002 18:54:07
Sounds like you got yourself an anchor for your Case boat. Happy Fishing!
