Dozer engine making weird noises
Jeb Mccranie
10-16-2002 16:36:58
The other day I cranked up my Komatsu bulldozer and a loud hollow tapping sound came from the bottom of the engine. It is quite worn out and needs an overhaul. I think it is the crankshaft journal but I am not sure.
D.L.
10-17-2002 18:10:12
 Re: Dozer engine making weird noises in reply to Jeb Mccranie, 10-16-2002 16:36:58
My guess is it's prob a crank bearing. I've seen bad rod bearings and they usually dont stop knocking when the oil pressure comes up.
Funny though, just had the same thing go wrong with my DB 885. Turned out to be the thrust bearings. A machine shop now has the crank and they are looking at using bronze to build the thrust right onto the crank itself instead of using a separate, tiny little bearing that fits into the cap. I'm no machinist, and the machinist tells me he has done this before and they last forever this way. I am also told that Long and other tractor makers now do this at the factory. Seems reasonable to me. Guess we'll find out.
Either way, if I were you, I wouldn't turn that motor over at all...get it pulled and rebuilt.
Pat T
10-16-2002 16:45:46
Sounds like a rod bearing, better not run it much more or you'll be able to look right into the side of the block to see what's wrong!
Pat
Jeb Mccranie
10-16-2002 16:57:00
 Re: Re: Dozer engine making weird noises in reply to Pat T, 10-16-2002 16:45:46
I will check that but what gets me is that the sound left after the oil pressure reached normal.
david
10-17-2002 06:44:19
 Re: Re: Re: Dozer engine making weird noises in reply to Jeb Mccranie, 10-16-2002 16:57:00
I agree that it is a bearing on the crank. My guess would be a main spun instead of a rod but that's really an academic argument. Either is bad, needs to come out NOW. Crank may still be turnable. Had a AD/54 Case-David Brown engine that only knocked on idel down from a hard pull. Low oil pressure had caused two mains to stick to the crank once, just for an instant. I o.h. it less than 20 hours after they first spun and had to turn to maximum (still left shadows).
Jeb Mccranie
10-18-2002 18:03:35
 Re: Re: Re: Re: Dozer engine making weird noises in reply to david, 10-17-2002 06:44:19
I tore the engine down and one of the crankshaft journals and an inch of play in it. If I had cranked that engine up on more time it probably would have broke lose. Thanks for all the advice. Will keep you informed on the rebuild.
