How to fix 2470 exhaust temp?
Shannon
10-15-2002 20:53:22
We have a 1972 2470 Case that we can't keep the exhaust temperature with in the "safe" range (under 1050 degrees). The tractor appears to have been turned up judging by the black smoke emitted under a hard pull as well as the power exhibited while under a load. The turbo appears to have been remanufactured as there is CaseIH reman printed on the ID plate. I should also mention that the tractor has 2600 hours on it. The exhaust temp climbs mainly when we're pulling a 27' disc or 7 shank subsoiler @ 16-18 inches. I am curious if an intercooler from a 2670 would aid in cooling things down. The water temp is fine throughout as long as proper warm up and cool down procedures are followed. The tractor has, as previously stated, plenty of power, but the high exhaust temp. necessitates shifting down. Any suggestions are appreciated.
Max
10-16-2002 19:25:39
 Re: How to fix 2470 exhaust temp? in reply to Shannon, 10-15-2002 20:53:22
I always thought that diesels ran from 1050�F to 1350�F under load. Ones that ran at a cooler temp were always underpowered.
Don
10-16-2002 19:11:09
The best way to "fix" it is to shift down a gear when the temp goes up. These engines do tend to run a hot exhaust when working hard. I ignored the exhaust temp on my 4494 and ended up with 6 cracked pistons, one with a big chunk out of it. Just what I needed 1/4 through seeding. After that engine job I kept the temp down and never had any trouble in the next 4000 hrs, until I traded it off.
Don
10-16-2002 19:10:26
Pat T
10-16-2002 16:36:06
Shannon-
We have a 1977 2470 we use on a 7 bottom plow, and see the same thing on occaision. When we first got the tractor a couple years ago, the pyro was bad, but that showed no exhaust temp. I was kind of wondering the same thing as you when I saw the temps up to almost 1200*, until I considered that the tractor was pulling those plows through heavy clay ground at nearly 6 mph! I just figured maybe I better behave myself and let the pyro set the ground speed. With only 2600 hrs on your engine, it sounds like it's running good for you.
Pat
david
10-16-2002 07:21:51
Also might try replacing the sending unit. I had a 2090 that showed first high water temp and then the transmission light would show trans temp. Neither was the problem. I had a wiring short on the top of the torque tube where the wiring harness crosess over (right side) under the cab. Apparently that short trashed all my sending units.
Other option is just ignore it. I've got a Mack road tractor that we haul dozers with. It runs hot exhaust all the time in a hard pull, Burned up a couple of mufflers. Now just running (water) pipes.
Tim
10-16-2002 07:16:06
Check to be sure the gauge is properly grounded. I thought my 1175 was running hot until I discovered the gauge had lost good connection with the dash due to rust and/or corrosion. When I completed the ground with a knife or screwdriver the gauge would drop 30 degrees.
