Forgive me Father for I have sinned! (A butchers story)
Billy
10-15-2002 14:58:29
Being in need of a tractor and having only a limited budget, I made the decision to buy the old tractor. A 1958 Case 801B, single wheel tricycle with the torque converter transmission. As luck would have it, about six months later the converter shredded out. Knowing that all I had at that point was maybe a couple hundred dollars worth of junk if I sold it, I started searching for parts and doing a little digging into the history of Case tractors. I couldn't afford a converter at $1500.00 (guaranteed rebuildable) if I could find someone who could and would do it, I found the next best thing. In doing my research I found out that 1957 - 1958 was a changover year for Case and that 400's became 800's and soforth down the line with little else being changed other than the model numbers. The biggest change for the 800's was the transmission change to the torque converter with lock-out. As luck would have it the local salvage yard had a 57' model 400 with a good trans/rearend for a song and a dance compared to the $1500.00 for a converter. And there inlies my sin, I butchered my tractor using my 800's front half and the back half of an earlier model 400. Thats right folks, I broke it in half, pulled the converter flywheel, put on a regular flywheel, clutch and pressure plate. Bolted that baby together and she's been running as strong as ever for the passed three years. Though I know that I shall forever be condemned in the eyes of the tractor gods, I smile and hold my head high knowing that sometime in the near future the 800's will die as the last good converter will be gone. But my 800/400 will still be running strong.
Pat T
10-16-2002 16:43:37
 Re: Forgive me Father for I have sinned! (A butchers story) in reply to Billy, 10-15-2002 14:58:29
You just made yourself a homemade 701B, Billy! Nothing in the world wrong with this, I bet it's been done a lot when ye olde farmer got the news he needed to drop $2K in the shop's lap to get the tractor to move again. No doubt there were a few more of these rolling around nobody knew about. Too bad you couldn't have swiped a WFE from the donor, the trike single wheel will be the best mudhole tractor stopper you ever did see!!
Pete
10-16-2002 11:16:50
As far as I know butchers only disassemble things. I think you need to refer to yourself in the future as a transplant surgeon. As far as I am concerned there are plenty of all original tractors in the world. I find frankenstein tractors to be a little more interesting.
caseboy
10-18-2002 10:41:52
 Re: Re: Forgive me Father for I have sinned! (A butchers story) in reply to Pete, 10-16-2002 11:16:50
if you like morphadite tractors then you need to come to my father and my farm. we have nearly 24 tractors and none are stock. we have an ih 1066. the 1086 had lots heavier stearing and ta clutch pack so we changed over. we have a 1938 grahambradley that has ford 1 1/2 ton differential and axles cause they were stronger but took some work to make them fit. we have a 52 D with a 2020 Deere carb on it. the new carb has lots bigger jets and gives more power plus it has a round nipple to put a rubber hose on to use a dry aircleaner which is mutch less restrictive than case's own oil bath aircleaner. we have a 29 L with around 14 modifications; it has LA front axle to get the rubber front tires, LA steering to get easier steering with a rubber steering wheel, and a LA trans to get faster and quieter gears and a road gear. none of those conversions took and machining. it also has a model a ford generator to power the lights. enjoy your unique tractors.
CASEPOWER
10-16-2002 15:04:40
I have a tractor in my salvage that I don't even like to admit I have. It is a Massey 22 with a chevette engine and trans in it. Around here we call it the masseychevette. The front end got a little hairy at about 40 mph so I decided to part it out.
Jeff
10-16-2002 06:00:00
thumbs up all the way Billy! keep that old girl working..
Don L.
10-16-2002 05:38:25
I have one also. But was too ashamed to speak of it. Glad you bring light to this 1/2 sin,we need a therapy group, and go from there. YES I SAY!!!! YES. I have one. I don't care what anybody thinks now. I am not alone..... Don L.
Larry
10-15-2002 22:31:22
I think the God's will be smilling down on you. You just saved another Case tractor from the bone yard.
Don L.
10-16-2002 05:50:03
 Re: Re: Forgive me Father for I have sinned! (A butchers story) in reply to Larry, 10-15-2002 22:31:22
My boneyard,like the grimm reaper, will sight on somthing , and it turns out to be a "swing and a miss". Beware the grimm reaper{on the second swing}.
Zach
10-15-2002 20:20:20
We have a 400 with a 500 bellhouseing and a 300 tripple range tranny. and a 430 pto the case-o-matic junked out on us. that aint as bad as what CASEPOWER has done to his Case C. As long as it says case and runs it don't matter what modles you cross breed as long as it runs and works. ;)
CASEPOWER
10-16-2002 15:08:47
 Re: Re: Forgive me Father for I have sinned! (A butchers story) in reply to Zach, 10-15-2002 20:20:20
Now you got me feeling guilty. OK the WC part is a Fairbanks morris mag. so it's not really allis and the rear wheels are new holland and I beleive they were made by Firestone or at least thats what I am gonna claim...
Zach
10-16-2002 17:14:14
 Re: Re: Re: Forgive me Father for I have sinned! (A butchers story) in reply to CASEPOWER, 10-16-2002 15:08:47
Thats your story and your stickin to it. right?? lol ;)
CASEPOWER
10-15-2002 18:30:46
Now you tell me there are tractor gods!!! I have a Case C with DC, SC, Allis WC, and new holland combine parts on it and I am building a VAH puller with a VAC front. I know the VAH is rare, but all I got was the back. I guess the tractor gods will really give it to me. Maybe even make me drive a deere!!! No now they couldn't be that mean.
Les...fortunate
10-15-2002 16:21:15
You have my congratulations. Be ye a Yankee by any chance? You know what our motto is, don't you? "Use it up. Wear it out. Make it do or do without." And I don't mean a Noo Yawk Yankee, neither ";^)
Billy
10-15-2002 16:54:32
 Re: Re: Forgive me Father for I have sinned! (A butchers story) in reply to Les...fortunate, 10-15-2002 16:21:15
Pure Texan thru & thru.....
