VA hydraulic/power steering system question
lee s
10-15-2002 06:11:12
I have a VAIW case that I have added a hydrualic/power steering pump that I took off a Case combine. The pump has inlet/outlet ports for the high pressure side and inlet/outlet ports for the powersteering side. Am I correct to assume that I should look at this as two different pumps? Each side requiring supply from the fluid supply tank and returning back to the tank after the valves/cylinders?
Dennis/Ohio
10-17-2002 02:38:30
 Re: VA hydraulic/power steering system question in reply to lee s, 10-15-2002 06:11:12
Hi, I used a combine pump on my 530 Utility. It has the power assist cylinder. Only the front pump had a relief valve so I plumbed the two pumps together to share the relief valve. I couldn't find a good steering pump and this has been working great for over 70 hours. Dennis.....
CASEPOWER
10-15-2002 18:34:37
Yes, That is what you have is two pumps with one shaft driving both. The power steering lines should be smaller for less flow and it was more then likely a complete hydraulic steer and not just power assist and the steering had a orbital steering valve.
