VAC-14 hydralics
Ron Saul
03-16-2006 04:03:02
I have a 1956 VAC-14 tractor. My book shows the hyd. pump is in the pulley area and the power tube and differential is to be filled with 140wt gear grease. My tractor has the hyd. pump up front like on a super A international and has hyd. power all the time. the suction and return lines run to the power tube area. The power tube and differential are filled with hyd. fluid. I had a wheel seal start leaking and during changing it I found hyd. fluid. Is this CORRECT? Has someone changed this tractor over to live hyd. and not added an independent hyd. tank? I'm worried about the differential and pto and such, running in hyd. oil.
Jerry W
03-16-2006 05:13:09
 Re: VAC-14 hydralics in reply to Ron Saul, 03-16-2006 04:03:02
The torque tube hydraulic system run off of the belt pulley was the only system available before the Eagle Hitch came in 1949. I have seen it on later tractors however. It is a self contained high pressure/low volume system that was only designed to run a rock shaft and the utilities that could be attached to the rock shaft.
The hydraulic system that utilized the pump run out of the magneto hole was a low pressure/high volume system and used the torque tube as a reservoir. Its primary job was to actuate the Eagle hitch although a remote setup was available. Hydraulic oil should not have been able to get in the transmission or rear end unless it was put in there intentionally or leaked from the torque tube. I cannot imagine that much if any damage was done to the drive train by using the wrong oil unless the tractor was worked very hard. I always use the saying a neighbor once said "any oil is better than no oil". I would change the fluids back to what was recommended and get back to farming.
Jerry
Ron Saul
03-16-2006 06:42:02
 Re: VAC-14 hydralics in reply to Jerry W, 03-16-2006 05:13:09
Thanks Jerry
mj
03-17-2006 15:50:33
 Re: VAC-14 hydralics in reply to Ron Saul, 03-16-2006 06:42:02
third party image
Click the link for more info.
