Is there supposed to be a plug on the cast iron piece?
Nicholaus Sowde
10-14-2002 17:52:33
I bought a Vac and I took the cast iron piece that goes from the bottom of the radiator to the engine block. on left side of tractor and it had a plug on the hole that goes up against the radiator. Is there supposed to be a plug on the cast iron piece? Thanks alot.
Bruce Nelson
10-14-2002 18:01:34
 Re: Is there supposed to be a plug on the cast iron piece? in reply to Nicholaus Sowder, 10-14-2002 17:52:33
Nicholaus, there is a drain plug in the cast elbow. Case put a two piece drain valve in this hole, not a plug. They used a drain valve like that to drain the block also. (located below the generator) If this valve got lost or damaged, putting a pipe plug in it's place would work fine.
Bruce
