Compression Test on DB 885
Eddie in KY
10-12-2002 12:24:16
How do you test the compression on this thing, and how much compression should it have?
Elmer
10-12-2002 18:45:11
 Re: Compression Test on DB 885 in reply to Eddie in KY, 10-12-2002 12:24:16
You have to pull all the injectors out. You canuse an old injector with out the tip i it and a compression gauge. You should have at least 375 psi. Ideal is 425.
