311-Case hydro/diff oil what kind?
Gary
10-10-2002 20:41:04
how much oil does the hydro system take it seems trannny and hydro all the same! also what type! thanks,gary
C. Amick
10-11-2002 09:25:16
 Re: 311-Case hydro/diff oil what kind? in reply to Gary, 10-10-2002 20:41:04
No, the hydraulic system pumps out of the front section of the transmission only. The manual calls for 30 wt. motor oil. The rest of the transmission and rear end get 90 wt. gear oil.
Gary
10-12-2002 04:06:45
 Re: Re: 311-Case hydro/diff oil what kind? in reply to C. Amick, 10-11-2002 09:25:16
ok if thats the case I cannot figure how when the lift is operated the supply comes out from the front pump area where you are mentioning. what gets me on my tractor I do not have a return line from the lift. seems if it dumps the oil straight down into the rearend. your theory where does it return from. seems funny to me! thanks
Joe (Wa)
10-12-2002 20:13:14
 Re: Re: Re: 311-Case hydro/diff oil what kind? in reply to Gary, 10-12-2002 04:06:45
Hi Gary, Mr Amick is correct. The torque tube & transmission are separate sumps and take different oils. The eagle hitch piston is single acting, when the lever is in the lower (dump) position the oil returns to the torque tube reservior via the supply line and interlock block. Good luck, Joe
Gary
10-13-2002 06:24:33
 Re: Re: Re: Re: 311-Case hydro/diff oil what kind? in reply to Joe (Wa), 10-12-2002 20:13:14
thanks a million . you know this form of info on the net and sharing hints is truly incredable!ok now how much oil in the hydro and how much in the rearend!
Joe (Wa)
10-13-2002 13:25:28
 Re: Re: Re: Re: Re: 311-Case hydro/diff oil what kind? in reply to Gary, 10-13-2002 06:24:33
Hi Gary, torque tube capacity will be 14-16 qts depending on drive options (standard, triple range, shuttle, multi plate clutch, etc). Dipstick is attached to plug on cover plate, drain plug is just fwd of transmission/torque tube mating flange. Transmission sump is approx 28 qts. Dipstick is attached to fill plug located by shifter cover plate, drain plug on bottom just aft of axles. Owner's manual: torque tube = 10 wt motor oil, transmission = 90 wt gear oil. I am using GP tractor hyd fluid & 80-90 GL5 respectively. Good luck, Joe
Zach
10-13-2002 13:04:57
in the rear end we put 5 gallons in our 430. and i can't remember how much hyd fluid we put in. seems to me like 5 gallons also but i am not positive. have fun and good luck
