Losing Power
Lee
10-09-2002 12:28:04
Case 631 Diesel w/ Caseomatic starts fine and runs good for a few minutes, then it starts losing power. Thought it was filters, so the fuel and oil filters were changed but still have the problem. Is it injectors, or is there something else that I'm missing? Thanks for any help on this!
Greg Williams
10-12-2002 08:31:28
 Re: Losing Power in reply to Lee, 10-09-2002 12:28:04
I have a 1940's model Case tractor. 4 cylinder gas motor. While my brother-in-law was bushhogging it got slower until it would not pull itself. He told me that the tractor was not smoking when this happened. Air & gas filters have been replaced. Still no power. Could this be a burnt valve?
Butch/OH
10-09-2002 18:42:12
It might be a plugged fuel return line. Take the fitting out of the top of the pump, running it with the fuel spilling out the top of the pump for a while to see if there's a difference. There's a check ball in the fitting coming out of the pump that gets plugged.
klyde
10-10-2002 09:54:53
 Re: Re: Losing Power in reply to Butch/OH, 10-09-2002 18:42:12
butch is right also want to check those eastman connector on the injector returns. I've had those break down over the years and little pieces plug the return line. I'd take it loose at the tank first and see what kind of return i was getting
Jeb Mccranie
10-09-2002 16:18:00
Sounds like internal engine problems. Do compression test.
Forgot to mention somthing
10-09-2002 16:35:30
 Re: Re: Losing Power in reply to Jeb Mccranie, 10-09-2002 16:18:00
If it smokes heavily at start up(black smoke) and clears up after the engine gets warmed up it might be an injector.
