Did case make a VT?
Randie
10-08-2002 19:18:52
I was given a tractor that is in pieces. I was told that it is a 1949 VT. I looked for a serial number but the only numbers I can find is a casting number, VT 161, on the transmission shifter plate and a casting number on the left transmission case VT 241. I would like to get a head gasket and button this tractor up before the snow flies here in Montana, which could be any minute. I would appreciate it if anyone could help me out. Thank you, Randie
Steve Staysko
10-08-2002 19:54:08
 Re: Did case make a VT? in reply to Randie , 10-08-2002 19:18:52
No Case did not make a VAT. The VT number that you are quoting is the generic part number for VA Case tractors. Your tractor could be a VA, VAC-11,12,13,14,VAI,VAIW,VAO,VAO-15,VAH,VAS all were manufactured from 1942 - 1955 some a little later than others. The tractor serial number is located on the tractor dash. If you have the S/N check out the Serial Numbers under the Reseach & Info. in Yesterday's Tractors web page and click on a model to see the serial numbers and the years it was manufactured.
CP
10-08-2002 19:37:32
What you have is a Case VA series tractor. The part #s you are seeing begin with VT. Head gskets are easy to get. Check with your local Napa or Carquest. Just tell them a Case VAC with a 124 Cid engine..
