It was a good weekend.... Case 200 runs
Mike Johnston
10-07-2002 11:17:07
Got the 200 running this weekend. It has sat unused for 10 or more years under an old shed, but fired right up with a carb disassemble/clean and points/condenser change. Heck, even the loader acts like it wants to work. It can barely lift its own weight now, but I bet it won't take much to get it working properly. I had thought this was a Model 21 loader, but those only had one dump cylinder. This has two, and the serial number seems to pre-date the numbers in the Model 21 parts catalog aquired off Ebay.
It does not have a PTO shaft, just a plate covering the hole. Can a pto be added? Also, the rear lift does not move at all. I haven't tried to diagnose that yet, but sure hope it can be repaired without too much expense.
The steering has been repaired & modified too many times to be useful anymore. Is anyone parting out a 200 series with wide front? I'll be looking for steering & other parts soon.
Mike Johnston
Houston, Texas
Zach
10-07-2002 17:16:33
 Re: It was a good weekend.... Case 200 runs in reply to Mike Johnston, 10-07-2002 11:17:07
We have a 430 with the 21 loader and it has a two dump cylinders but i think someone has modified it. we still have problems with it. good luck. there alot fun to use.
Jeff
10-07-2002 14:12:46
good for you Mike, keep on fixing her and have alot of fun.
Jim M
10-07-2002 14:10:33
I'm parting out a 311. I think the PTO and steering parts will interchange. I'm in South Florida. If we can find a way to get them to you all will be good. It has a straight front axle like on a ulitity tractor
Mike Johnston
10-08-2002 16:18:31
 Re: Re: It was a good weekend.... Case 200 runs in reply to Jim M, 10-07-2002 14:10:33
Jim,
I was in your neck of the swamp a couple months back. Bad timing....
Mine also has the straight axle (wide front). Does yours have the power steering cylinder?
mj
