hey thad 2290 puller
case trader
03-15-2006 17:30:04
Thad i was considering pulling a 2290 8 speed 4 post in the field stock class i see a couple of 1175's in your area pulling is the 2290 to heavy?will the 8 speed stand the pressure? any thoughts
Thad
03-15-2006 17:50:49
 Re: hey thad 2290 puller in reply to case trader, 03-15-2006 17:30:04
I guess my first thought is what weight classes do have to try to get into? What is the hottest thing you might be up aginst? I dont know anyone pulling one of them. I think it would make a great 12500lb and up tractor were you dont need tremedous hp. Most guys just run the 70 series 8 speeds either 970 to 1175. I think the clutch could be the weak spot if you really get the hp up on it. You should be able to get 190 or so with the stock pump. Put a modified 10mm pump with a 3lm charger on it and things might not hold up. I think if you stay in the upper 180s area and all you do is pull at tractor pulls it will probubly hold up. But the guy who trys to farm with it like that running it 10hrs every day pulling a subsoiler at 16000lbs will have trouble. Just my two cents Thad
