(The original copy of this post got deleted because Dillon had replied to it. Kim was kind enough to give me a copy of my post so I wouldn't have to re-type it, and I'm adding it to the board again. A big "thank you" to Robert Kelley and Baggsy who gave me good engine advice before the original post got removed last night...)Hi All, Well, I've got a new project tractor now- I recently bought a '49 DC to be the big brother to the '49 SC. I don't have any ownership history on this tractor- and I don't know how long it's been sitting... but it appears that both the engine and clutch are currently stuck. I guess that my earlier SC project spoiled me- as I had no problems whatsoever with the engine or clutch on it, and it had been sitting outside for 12 years. Perhaps this weekend I'll start working on assessing the state of the problems with the DC, and I could really use some advice from the group as to where to start & how to proceed with unsticking this old girl. F.Y.I. - I'll be doing all the work on this tractor outside for now... so I don't plan on doing a full teardown. (and I definitely don't want to split it) My goal at present is to see if I can increase my odds of returning this to a running tractor before fully committing to the resto project. Here's the plan of attack that I'm thinking of taking- everyone feel free to offer advice or a different approach or a better way to accomplish what I'm after: 1) Pull the starter to make sure a stuck/engaged starter isn't acting like a stuck engine. 2) Pull the oil pan or inspection plates and have a look at the lower end of the engine. (The oil that's currently in there looks clean and good.) 3) Pull one or both of the clutch inspection plates and see what I can see. I don't have ANY idea what to do about the stuck clutch. I don't plan to split the tractor until I know that the engine is a "go". All clutch advice will be greatly appreciated. I think the DC clutch operates opposite to my SC clutch... but I haven't figured out whether it is stuck in the "engaged" or "disengaged" position yet. Lots of advice in the archives on adjusting the clutch, but very little on unsticking one. (The belt pulley/engine will definitely NOT budge when the tractor is in neutral.) 4) Soak the cylinders with magic fluid to see what happens. After reviewing the archives, I think I've decided on the 1/3 kerosene, 1/3 Marvel Mystery Oil, 1/3 transmission fluid recipe. All 4 plugs are still in, so nothing should be in the cylinders unless it came in through the stack/valves. 5) Install rear tires so I can put the tractor in gear and start rocking the wheels back and forth. 6) Pull the valve cover and soak the valve stems and rocker arms, too. 7) Pull the cylinder head and look at the top end (if nothing else works.) 8) If I get the engine free, then I plan to fill the radiator and see if I get any coolant leak-by the O-rings and into the oil pan. There doesn't appear to be any coolant in the oil now... but that radiator looks bone dry. Thanks in advance- I'll try to post some pictures when I get a chance. -Schotte
