case 580c
nawsd
03-15-2006 06:49:08
Thinking of buying this hoe (at auction) has water in oil.Sheet metal is in rough looking shape,buckets and pins/bushings look pretty good has had all hyd.cyl. replaced two or three yrs. ago.The man who ran it said it was not run hot nor had it been cold enough to freez,he also said when it got hot trans would not pull well in foward but always good in rev.What could cause these problems at least and worst conditions? Has been sitting up over one year.Any advice? How much is it worth? THANKS
Walt Davies
03-15-2006 07:45:35
 Re: case 580c in reply to nawsd , 03-15-2006 06:49:08
By the time you rebuild the engine and rebuild or replace the shuttle it will cost more than the tractor is worth I'd look around there are lots of them in much etter condition for about the same price. Unless he want to pay you to haul it away (giggle)
Walt
nawsd
03-15-2006 10:44:01
 Re: case 580c in reply to Walt Davies, 03-15-2006 07:45:35
Is it worth 1000-$1200? Is there any other seal (other than piston sleave)that could cause water in oil? Are there bands in trans that can be adjusted? any input from anyone with knowlege or experience on this would be appreciated.THANKS
Dennis/Ohio
03-19-2006 17:03:18
 Re: case 580c in reply to nawsd, 03-15-2006 10:44:01
I was told by a salvage yard. A 580 probably cant be bought for less than $5000 because the parts are worth that amount?
