LA engine rebuild
Richard
09-29-2002 17:13:41
My I@T manual says a fiber washer goes behind the cam gear against the block to act as a thrust washer. My Case dealer says no longer available.
Of the 5 engines I have torn down, None had a fiber washer. Is it necessary and if so, what would be a source?
Thanks, Richard
Frank
10-01-2002 05:41:26
 Re: Re: LA engine rebuild in reply to Don L. @ Rusty Acre, 09-30-2002 08:11:21
Most bearing supply houses can get thin bronze thrust washers,just give them the I.D. and O.D. and thickness and they should be able to fix you up.
