Help ID 530 clutch/trans
Scott
09-28-2002 11:41:40
I looked at a early 530 yesterday. The guy told me it was a hydraulic clutch tractor. I am not familiar with Case Torque Converter drive, but I think this tractor may have it. The clutch pedal is hooked to a hydralic assembly valve, and there are lines that run up to the front to a filter housing. The tractor has a high low range lever on the torque tube, and a lever to the right of the steering wheel that looks like a throttle lever, but seems to change the speed of the tractor slightly. This is not a utility but a farm tractor with 14.9x28 rears and a pipe type front axle. Grinds a little when going into gear. Metal and paint is rough, rims rusted through on back, but engine is smooth running. Has eagle hitch not a true three point. Did the actual swinging three point come on later model tractors? He is asking $2800 in Ohio, is this fair? Is the transmission a problem?
Thanks,
Scott
Terrance
09-30-2002 05:36:15
 Re: Help ID 530 clutch/trans in reply to Scott, 09-28-2002 11:41:40
Last I knew rebuilt torque converters were available from Case at a resonable price.The 530 was available with the Eagle hitch or the Draft-o-Matic(swinging draft arms with draft sensor).I prefer the Eagle hitch, much easier to hook up with and no sway.The price seems a bit high for a tractor with problems,but it also depends on how much of the work you plan to do yourself and your abilities.They are fairly simple to work on and most parts are available and resonable.
Good Luck
Terrance
Junkyard Wars
09-29-2002 06:57:22
seems normal, price is fair.
Don L.
