I asked in another post about a problem with the hydraulics on the DB 885G I just paid for. Well, now I know "the rest of the story". First, it seems our local Case dealer/shop isn't too thorough in their garage work. This place did the install on the new hydraulic valve body and valves. On the repair paperwork (which I have in hand), the mechanic checked off the install had been done and notes that the hydraulic oil looks ok and does not need changing. Well, it turns out the hydraulic oil was the problem! Seems the mechanic dipped some from the top before he installed the valve body and, of course, having set for so long, all the gunk and sediment was in the bottom. We replaced the hydraulic filter (under the bottom of the tractor) and in the middle of where the filter goes is a bypass valve that is spring operated. It also has a magnet to pick up any small metal grindings from wear and tear. This thing was all gunked up and the bypass valve wasn't "bypassing". We drained the entire system and flushed everything with diesel fuel. Cleaned everything up and replaced the filter and hydraulic fluid fresh. Everything works like a charm now. One new "problem" of sorts...when the tractor is first started, there is some clunking in the bottom end of the engine for about 1-2 seconds and then it goes away. Mike (the seller of the tractor) thought it might be a bearing because once the tractor heats up, the oil pressure drops to about 20 PSI (assuming, of course the old gauge is accurate to begin with). We pulled the pan and sure enough, the front main thrust bearing had worn away, or fell out (it's a little, half cirlce bearing that fits into a rather narrow and shallow channel in the side of the front and rear main caps) and the crank was moving back and forth a slight amount. It has worn into the side of the cap to the point one of two things needs to happen. A new cap needs to found and bought, or a machinist needs to build the area up and machine it back to correct shape. New bearings are coming as well. Mike is going to have this work done for me, and there is no extra charge for any of it. I almost feel sorry for Mike...this tractor ended up costing him more than he intended to put into it, and although I have already paid for it, he still insists on doing these things so that it's "right" when I finally get to take it home. He has already spent a fair amount of the money I paid for it to fix some things up. All I can say is it sure is good to find an honest, hardworking guy these days that's willing to do what it takes to make things right. If/when I need another tractor or other implements, or any type of work on the tractor, Mike will definitely get my business.
