DB990/WAIN ROY BACKHOE HYD.TROUBLE
rob
09-25-2002 17:19:38
My hydraulic fluid is overflowing from resevoir. It looks foamed up like air is entering somewhere.When this happens I lose all functions. Does anyone know what would cause this? Also I cant find the location of the filter for hydraulic fluid. Is anyone familiar with Wain Roy backhoe. I have looked everywhere except in the resevoir itself. Could the filter be in there where the return line enters?I think it overflows due to the increase in volume when air enters. Any help would be appreciated. THANK YOU
Elmer
09-26-2002 04:25:30
 Re: DB990/WAIN ROY BACKHOE HYD.TROUBLE in reply to rob, 09-25-2002 17:19:38
I am not familiar at all with the Wain Roy backhoe. In fact i have never even seen one except in a picture. Air can enter the hydraulic system by the shaft seal on the pump or a bad suction hose. I'm guessing at this, because i don't think Wain Roy would have used the hydraulic pump supplied by David Brown in the pto housing. You would have to take all day to do a few functions. They only put a 5 gallon pump in it. The Hydraulic filter is probably inside the reservoir if you don't see one on the return line.
