Case VAC
HoyBoy
09-25-2002 02:58:18
Can a Case Vac be used for running a square baler?
wheat straw
09-26-2002 13:50:23
 Re: Case VAC in reply to HoyBoy, 09-25-2002 02:58:18
Hoy,
Have found that the vac will do it on a pto baler if it is not to big a baler. Have pulled a new holland super 69 and an IH 45. Made a 45 to 50 pound bale in grass hay. The rake boy better know what he's doing. You need a small windrow without any piles in it. you'll also need to learn to do a speedy job clutching, jerking out of gear and letting out on the clutch in a hurry. You need to do this in one fast sweeping motion between power strokes of the baler.
It is going to jerk the tractor around and if the old knotters are loose and worn it will agrivate the "mssed bale syndrone" as the knotter will tend to slop around with the lack of power. When the old ih baler got wore out you could tell a difference in the way it tied from the vac and my brothers case 400. Seemed like the smooth power of the 1955 400 was a big help. It's not fast and it yanks you around a little but it will make usable bale.
Be careful on the turns. VAC's dont like chattering u joints and will explaine their dislike to your wallet. The pto gears are the vac's weak point. good tractor and able to do more than some folks think. not always convenient but doable.
have fun
Wheat Straw
Augie
09-25-2002 09:09:54
Sure, but you'll need a baler with its own power source.
