Not sure what I have -- Case 200?
Mike J
09-24-2002 12:28:29
An uncle gave me an inoperable Case tractor with front loader. The only markings I can find is the number 200 on the hood, and a serial number 4013696. It has a gas 4 cyl motor and no PTO shaft. I'd sure like to get this thing running again, and put it back to work.
If anyone can give me any info as to date of manufacture, model, etc and where to find parts, I'd sure appreciate it. I know for sure it will need a total steering overhall, & the 3 point equipment has been removed.
Thanks,
Mike J
Dennis/Ohio
09-25-2002 02:49:52
 Re: Not sure what I have -- Case 200? in reply to Mike J, 09-24-2002 12:28:29
Hi, I think I have the remains of the same model tractor. Mine is a 210B-H Utility Tractor. It had a model #21 Loader when new. Only 394 units built. The serial number you listed must be for the loader. Tractor tag should be or was on the dash. Your 126 engine will accept 148 pistons & sleeves. Many 310B parts will fit you tractor. Some facts that may help you: #21 loader has a single dump cylinder. Power steering is a single assist cylinder on a cast I-beam axle. Casting # on left side of 4-speed is G1096 & may have a casting date on the other side (date will be cast upside down). Hope this info helps...Dennis....
Mike Johnston
09-25-2002 08:23:16
 Re: Re: Not sure what I have -- Case 200? in reply to Dennis/Ohio, 09-25-2002 02:49:52
Dennis,
You are correct, that number is the lift serial. The tag on the dash is gone. Mine has that same cast number G1096 on 4-speed. There is a '200' on the cowling at the radiator.
Thanks for the reply, and email.
Mike Johnston
Houston, Texas
Mike J
09-24-2002 14:29:36
A photo of this tractor is on the Help Identify page of this site. See link below, and thank you for any info.
Mike Johnston
Jim M
09-24-2002 16:45:06
 Re: Re: Not sure what I have -- Case 200? in reply to Mike J, 09-24-2002 14:29:36
Case made the 200B tractors in 1958 and 1959. 126 cubic inch engine. You can post what you need on the classifieds on this site. I have a Case 300 I am parting out and may have some of what you need.
Mike Johnston
09-25-2002 10:48:08
 Re: Re: Re: Not sure what I have -- Case 200? in reply to Jim M, 09-24-2002 16:45:06
Thanks Jim,
After I get a better handle on what I'll need, I will post that info on the classifieds.
Mike
