Vac tractor
John Berra
09-22-2002 10:56:01
Need Help I am a city boy liveing on our new homestead. Have a VAC Case that will stop running after a few minutes of work. ( tractor was here when we got the place) Thinking of tuneing it up but need info and parts. Any info would be helpful!
Thxs
barry
09-25-2002 17:03:51
 Re: vac tractor in reply to John Berra, 09-22-2002 10:56:01
John, I read all the other guys postings and I agree with them. Tune that baby up. Rebuild the carb and make sure you've got good fuel flow. Being an updraft carb, it should condense water on a cool day. (outside of carb). I understand some early VAC has a magneto ignition. If so, check rotor and stator for rust. Insure they are clean and dry. If you've got 6 or 12 volts wired straight to the + side of your coil, it may be breaking down. A resistor for a 1974 dodge dart with a 318 worked for me. Drops it to 2.0 volts at the coil. If you've got a distributer, new points set a .020 and a fresh condenser should do the trick. Check the gasket between the carb and intake manifold for a good tight seal. All the air drawn for combustion should come through that 1.25 opening at the top of the oil wash filter. Good luck man.
barry
09-25-2002 16:03:52
John, I have a 1952 case vac. I would like to help you with your delima. You've got a fine piece of machinery. Be patient and call me back.
Grizzly
09-24-2002 09:27:30
Just last night went through similar problem with MF 165. Dirt in the fuel line. It would allow enough through after a few minutes to start and then would stall. Ours was in the shutoff valve just under the tank.
Marty
09-24-2002 08:44:47
Forgot one other place to look. The on/off switch on mine failed intermittent four years ago when I bought it, and is now acting up again !
Marty
09-24-2002 06:04:30
Don't just replace one component, do the points condensor rotor and cap if it tests out as no spark. NAPA dealer has all the parts you need.
geo
09-24-2002 05:04:30
I would pull a sparkplug wire, crank over and check for spark(1/8 to 1/4").
If you have spark check fuel, pluged line or carb. float stuck.
ff316
09-23-2002 12:28:11
You might try a coil as well. While your at it you culd change points and condensor, wires, plugs, cap and rotor. If there is no farm store in your area some auto parts stores carry these parts. If they are not in their books maybe they can match them up good luck, Fireman
Steve Staysko
09-23-2002 06:58:32
Sounds like it needs a new condenser. I had the same problem the tractor would warm up and then quit, after it cooled for a time it would restart.
Robert
09-28-2002 18:04:19
 Re: Re: vac tractor in reply to Steve Staysko, 09-23-2002 06:58:32
I used to go through this almost every spring after the tractor set allwinter. You probably have a dirty gas tank. Pull it off and rinse it out good. Check screen on sediment bowl as they will clog easily. It probably has a Marvel Shebler
carb which is a pain but should be taken apart and cleaned and blown out with air hose.They are not hard to work on. Check spark. If necessary change points{ I use Blue Point) and condenser.As has already been suggested use 12 volt battery with a resistor between 12volt coil and distributor. Your problem is probably dirty fuel.Hope this helps.
