How does SC 3point hook to toplink
Wayne Mo
09-21-2002 21:13:15
My 1955 foot operated clutch Case SC works fine but I have never used the lift arms on it. Also the pto seems unusually high off the ground! Where did the top link on the 3point system hook to. It must be clear up on the seat mount surface! I must be missing a bracket there or something. I only use it to pull things around except I did run a pull type brush hog with it and noticed how high the pto shaft was positioned on the rear of the tractor.
Harpal Singh
11-08-2003 03:58:20
 Re: How does SC 3point hook to toplink in reply to Wayne Mo, 09-21-2002 21:13:15
0161-432004
Dear Sir,
We are indrouce ourselves as manufacturs of all kinds is
Toplink assambly Export quality and As per your requirments , And mfr.
of weld on end Toplink and lowerlink .
We are sure you will find our prices the most competative
As suring you of our best service at all time.
Your's faithfully
Kartar Engg Works ( Regd ),
Cell;- +9198158-17937 Mohinder Singh
Cell;- +9198140-20937 Harpal Singh
Richard
09-23-2002 14:00:14
There are two places for the top line . First there is the one under the seat on top of transmission it should be to bolted to the left side of seat support , it looks like there is one missing but thats the way they came . This is for pto work on the EH . The other is a bracket(4205AA) that bolts over the pto used for plowing
Wayne Mo
09-24-2002 08:09:06
 Re: Re: How does SC 3point hook to toplink in reply to Richard, 09-23-2002 14:00:14
Thanks, you understand what I am talking about. What does EH mean? Is the underseat support bracket the same as the seat bracket itself or go next to it? My underseat support bracket has an ear broke off that mounts to the seat vertical support link, is there another missing ear for the top link or is there another bracket that goes next to the seat support bracketd? For the plowing bracket, does it just go completely over the pto and cover it up? I need to get one of these. Where are they available? Thanks again for the info...
Richard
09-24-2002 14:37:18
 Re: Re: Re: How does SC 3point hook to toplink in reply to Wayne Mo, 09-24-2002 08:09:06
EH eagle hitch , there is another bracket(09195 AB) and a spacer(09283 AB) that bolts on top of seat bracket . The plow bracket covers pto and bolts to the 4 studs around the pto , if you find two I would like one too .
Wayne Mo
09-24-2002 16:17:56
 Re: Re: Re: Re: How does SC 3point hook to toplink in reply to Richard, 09-24-2002 14:37:18
We may have to make one! It would help if we knew what they looked like but I guess we can improvise. At least we know where they go and what they are intended for! Something to look for in junkyards and farm shows.
