Injector pump timing on case 580b
JG
09-21-2002 17:46:49
Can anyone tell me how to set the injector pump timing on a case 580B. Where are the marks and how do you set ????
Dave Gehalo
09-30-2002 19:35:33
 Re: Injector pump timing on case 580b in reply to JG, 09-21-2002 17:46:49
According to my 580B manual first thing to do is refer to engine data decal on valve cover for specified fuel pump timing. On my 580B the decal has been painted over so I've never checked the timing.
Next - turn engine, using a screwdriver in the timimg mark access hole, counterclockwise (as viewed from the flywheel end) past specified pump timing; then turn back clockwise until timing pointer is in line with specified pump timing mark on the flywheel.
Next - remove timing window cover from the injection pump and check to see if marks are in alignment. If they are aligned your done.
If not aligned loosen pump mounting nuts. Move pump toward or away from engine until timing marks align. Note: advance is move top of pump away from engine and retard is move top of pump toward engine.
Dave
