Gear range selections
D.L.
09-20-2002 21:50:12
I've already asked this, and got one reply, but didn't understand what the poster said...so will try once more.
I am picking up the David Brown 885 tommorrow (that's the good part)...but...
I know it has 4 different ranges on the transmission (with 3 forward and one reverse gear per range).
The range lever is labeled: LS, L, H, HS
Any idea what the "S" stands for? Also, is there anyhting special about the "S" ranges other than they called that that instead of 1,2,3,4 ???
Thanks!
Eddie in KY
09-21-2002 19:37:50
 Re: Gear range selections in reply to D.L., 09-20-2002 21:50:12
I dont know what the "s" means either, but I am sure glad to be able to match ground speed to engine speed no matter I am doing.
D.L.
09-21-2002 21:00:41
 Re: Re: Gear range selections in reply to Eddie in KY, 09-21-2002 19:37:50
AHA! found out what the "S" stands for... "slow".
High Slow, High, Low and Low Slow.
HS range is a bit slower than H, but still faster than L and LS is the slowest range, so the order of the ranges (slowest to fastest) is: LS, L, HS, H
There is supposed to be a placard or sticker on top of the tractor that shows the speeds for the ranges/gears vs engine RPM, but it is long since faded and can't be read...but talked to a fellow locally that also owns an 885 and he showed me his tractor. I can read the placard on his.
Josef
09-22-2002 12:23:52
 Re: Re: Re: Gear range selections in reply to D.L., 09-21-2002 21:00:41
Gear sequence of my tractor:
Gear 1 = LS.1
Gear 2 = LS.2
Gear 3 = HS.1
Gear 4 = L. 1
Gear 5 = LS.3
Gear 6 = HS.2
Gear 7 = L. 2
Gear 8 = H. 1
Gear 9 = HS.3
Gear 10 = L. 3
Gear 11 = H. 2
Gear 12 = H. 3
1 R = LS. R
2 R = HS. R
3 R = L. R
4 R = H. R
regards, Josef
