Difference in stuckness of engines??
INCase
09-20-2002 09:59:19
Is there a difference in the severity of an engine being stuck due to sitting for a long time and an engine being stuck due to the use of starter fluid?? For example a 730gas engine??
Bruce Nelson
09-20-2002 14:45:19
 Re: Difference in stuckness of engines?? in reply to INCase, 09-20-2002 09:59:19
There is a big difference. An ether deal may be cured with forcing one or two pistons loose and replacing a few parts. I have seen some stuck engines (stuck for years) that need to have the rods torched off, (the rod caps cannot be removed because of where they are positioned in the engine), crank shaft removed and the pistons driven out with a sledge hammer with an oak block. This usually ends up with alot of parts that need to be replaced.
