SC
Oil in Exhaust - Need Advice
Rob G.
09-20-2002 09:49:20
I hope you guys can point me in the right direction to solve a problem with my 1950 SC. I have three symptons 1)a lot of black smoke from the exhaust 2)exhaust coming out of the vent tube on the valve cover and 3) an oil leak where the exhaust manifold bolts to the head at the #4 cylinder position. I would really appreciate any insight on what the problem is and how to fix it. Thanks in advance.
Test
10-05-2002 09:35:16
 Re: SC - Oil in Exhaust - Need Advice in reply to Rob G., 09-20-2002 09:49:20
Test
robert
09-20-2002 16:37:45
I'd say black smoke is from over rich fuel mixture and some oil burning.Alot of fumes out valve cover vent pipe to me suggests excessive blow-by(worn rings at best,worn pistons and cylinder walls)--worst!! Oil leak at #4 manifold is likely a bad sealing gasket possibly from warped manifold. Sorry but all this doesn't sound good,what you have told me.I would expect a worst case scenario.I think some of these old tractors are indeed full of life,and some are simply worn out.The bright side is You may enjoy the challange of curing its ills.Good luck on project.
Rob G.
09-23-2002 09:33:42
 Re: Re: SC - Oil in Exhaust - Need Advice in reply to robert, 09-20-2002 16:37:45
Thanks for your comments. I'm a little puzzled about the oil from the manifold gasket. If it was just a gasket leak wouldn't I just get exhaust gasses leaking out. Why am I getting oil at that location?? Thanks.
robert
09-23-2002 18:20:05
 Re: Re: Re: SC - Oil in Exhaust - Need Advice in reply to Rob G., 09-23-2002 09:33:42
if rings ,piston,cylinder are shot.it is likely that alot of unburned oil can end up in manifold and appear at gasket joint,if joint is not perfect.otherwise would blow out muffler. See that oil isn't running down from leaky valve cover gasket? *** test compression***!! inspect valve train with engine running,and valve cover off. look for stuck valve(s).inspect spark plugs too.good luck!
