What do you think about this 801B
Ricky
09-20-2002 07:32:25
The man is asking 1000 obo. He says there is a problem with the injector pump. It is the round one. He thinks that is the only thing wrong with the tractor. The caseomatic works and the engine runs but not smoothly. It is a NF but he has a WFE to go with it. The sheet metal is straight. It has good tires. He has also installed many new parts and put in new freeze plugs. What do you think about the price? Are these good tractors? He has to use ether to start it. What else do I need to look for? Thanks, Ricky.
RobertTX
09-20-2002 19:14:37
 Re: What do you think about this 801B in reply to Ricky, 09-20-2002 07:32:25
The either is an alarm, as indicated below. It really depends on what you expect of the tractor and what you want to do with it. If occasional use, it may be OK as is. These are strong tractors and can do a lot more than their designing fathers planned. If you are going to need it to make money, that is a different matter, you need to consider more closely. Diesel Injection Srvice in Lubbock, Tx has an excellent reputation, they also have a web address, but I don't have it handy, they may be able to offer advice. I have seen these pumps rebuilt priced at less than $500, you might want to verify that and look at the risk of other problems and make an offer. Good luck. I think these are pretty nice tractors, if you can get things working.
Jeb Mccranie
09-20-2002 17:01:47
If it having fuel pump problems and has to use ether to start it,don't waste your money on it.The engine probably has serious internal damage due to the ether,they just hav'nt came to the surface yet. Plus, fuel pumps are a pain,especially on diesels, and on some tractors it extremely hard to get the timing correct again.Tinkering with it will probably do more harm than good.
Jeb Mccranie
09-20-2002 17:01:23
