Need parts for Case SC
Wayne Mo
09-19-2002 20:50:06
Anybody close to Union, Mo. have used parts for Case SC listed below? I need these to finish up restoration of my late model SC which has a foot clutch.
Stamped brake drum that fits inside pulley used to stop the pulley for shifting. Mine wore completely in two by pervious owner!
Seat bracket that mounts to seat rear link. It is the top of the pto cover too I think. It has 2 ears on it that bolt to the rear link on the seat.
A double rubber biscuit that controls the seat movement. I know these are hard to find and are expensive new.
Thanks.
jal-SD
09-20-2002 06:14:05
 Re: Need parts for Case SC in reply to Wayne Mo, 09-19-2002 20:50:06
Wayne, Min-Kota Repair, 38893 County Hwy 14, Ortonville, MN 56278 has the rubber bushing for the seat. Nice folks to work with. I got one from them for my '54 SC w/foot clutch this spring. (They ARE spendy - $125 + tax & shipping.) Ya gotta rivet them in to your brackets. Be sure you know the angle of the brackets BEFORE you rivet them. (Don't even ask how I know this!) I sent them my old one so they could match it, as they told me that there are several different types. They have the brass bushings too.
Have you tried your friendly C-IH dealer for the clutch part? They got several parts for mine that I didn't think they could, but they didn't have a clue on the seat. All they had in their parts book for seat "stuff" was the old type. The serial # on my '54 is 8040993, whats yours? (My $0.02 worth. jal-SD)
Wayne Mo
09-21-2002 21:01:15
 Re: Re: Need parts for Case SC in reply to jal-SD, 09-20-2002 06:14:05
Thanks for the info on the seat rubber biscuits. I knew they were expensive but have not figured out how to replace them otherwise. My serial number is 8031559 and it is a 1955 model. The local dealer here did not have the brake pulley clutch part but I think I can make one if I can find a steel part that is 5 in in diameter to weld onto the old one. I assume the $125 is for both biscuits!
