Head swap on CASE LA
Texas Red
09-18-2002 16:22:49
I just got a CASE LA 1953 home and in the work bay. It has a busted head due to freezing, This is a gas tractor . I can get my hands on a 53 propane tractor for parts. My question: Will the head off the propane fit on the gas engine and if so will i see any improvement in HP?? I can also get another gas tractor for parts, which one would be best? Thanks for the help. TR
scottAR
09-22-2002 16:38:44
 Re: Head swap on CASE LA in reply to Texas Red, 09-18-2002 16:22:49
I would change the whole tractor over to propane. Much cleaner and longer lasting like the other 100,000 tractors in TX.
Richard
09-23-2002 09:50:22
 Re: Re: Head swap on CASE LA in reply to scottAR, 09-22-2002 16:38:44
But according to my ag engineering friend at Clemson University, the gasoline gives more power with the higher compression than does the propane.
Richard
aws1234
09-28-2002 06:25:22
 Re: Re: Re: Head swap on CASE LA in reply to Richard, 09-23-2002 09:50:22
The statement that gas will produce more HP than
propane need clarification - You would need
gasoline with at least 130 octane for this to
be true - You need something over 130 psi to
properly use propane. Most propane tractors
where built to run Butane - hence the lower
compression available from manufactures for
propane tractors.
Richard again
09-19-2002 17:22:07
I have used a propane head on a gas LA for years pulling a 9 foot double disc and a 2 yard dirt pan. The power is amazing.
I am restoring another gas LA and am going to put a propane head on it also. The propane heads have hardened valves and work well with unleaded gas. If you need valve seats when doing a valve job, go to Otto Engine Works on the web. They are very reasonable and good quality.
Richard
Texas Red
09-20-2002 03:37:30
 Re: Re: Head swap on CASE LA in reply to Richard again, 09-19-2002 17:22:07
Thanks for the info. I think we will go check out the propane unit. TR
wheat straw
09-19-2002 10:16:01
Tex,
I'm not a mechanic and don't know the combo but on the dc anyway you need to match the pistons with the head or you can have a problem. high compression piston is taller. If you have high compression head and piston, it will cause a collision on the poston top. guy once hade a dc souped up and could pass an m farmall with the same plow about every third of fourth round. Lasted untill just after dinner untill the crank broke though. Expensive day of plowing but was it ever fun. my brother wound up buying it for a song and using the parts in two other engines. there were several head and piston combos. probably same on the la. watch out. the right combo can be a masterpiece though.
Wheat Straw
bill koob
09-28-2002 06:32:28
 Re: Re: Head swap on CASE LA in reply to wheat straw, 09-19-2002 10:16:01
We did this all the time - need to line bore
the crank. Now would probably chemically treat the crank too. We had DC propanes - took the heads and milled them 125 thousand. They were hot
rods putting out honest 60 hp.
RobertTX
09-19-2002 05:51:10
The propane head will fit and is a pretty desirable item for the pullers, definitely a HP increase. Also, the propane engine will likely be cleaner and less sleeve/piston wear. I have heard some people have trouble with pinging, but that should not be too hard to overcome. What part of Texas are you in? I would be interested in sharing or trading parts.
Richard
09-19-2002 05:46:43
Yes, it will fit and if in good condition, you should gain at least 5 HP over the gas head an would gain about 10 over a kerosine one.
