VAC missing belt pulley
Roger Rachow
09-17-2002 18:19:50
Hi, I bought a Case VAC unfortunately I didn't notice that the belt pulley was not there. There is a metal plate with 4 bolts over the place where a belt pulley should be. Any ideas as to what I should do to restore this part. Where and what would I buy to replace it?
Thanks
Roger
TB
09-18-2002 07:55:01
 Re: VAC missing belt pulley in reply to Roger Rachow, 09-17-2002 18:19:50
Sounds to me you are missing more than the belt pulley. What year, what type of hydrolics does it have?
Roger Rachow
09-18-2002 15:24:38
 Re: Re: VAC missing belt pulley in reply to TB, 09-18-2002 07:55:01
its a 1946 Case VAC, hydralics I have no idea. On the side where the belt pulley should be they simply put a steel plate attached by the 4 bolts that are orginally there. Help
TB
09-18-2002 19:01:17
 Re: Re: Re: VAC missing belt pulley in reply to Roger Rachow, 09-18-2002 15:24:38
Some of these didn't have a belt pulley or the hardware for the use of hydraulics�. Look in the photo gallery to see if you have that hardware. If you just want a belt pulley you may get away with just a hydraulic pump housing assembly and a pulley then you can plate off the bottom of the housing where the pump would go. There were several versions of original.
JEAN CLAUDE MARLEAU
09-17-2002 19:10:50
HI ROGER I DO HAVE A BLET PULLEY FOR YOUR VAC BUT I MUST TELL YOU THAT I LIVE IN ONTARIO CANADA IF THIS STILL SUIT YOU PLEASE LET ME KNOW NICE TALKING TO YOU
