Need info on Case Construction King Backhoe
Bill b
09-15-2002 19:54:43
Recently purchased in estate sale a Case Back hoe, They called it a Construction King. Model says it is a #42 Serial # on hoe is 4059572, operators 4868676 or the 7 could be a 1 stamp on gas engine is a GWC K -30
Would line ino on year, fluids used and where and how to look up to buy manuals. I have looked on this sight and no modle 42 no construction king etc. This is my first backhoe for the small farm I have used wF in the past but was told these were good backhoes even if they are gas. I need to convert generator also to alternator and find muffler number before winter sets in
contact me at [email protected]
JEAN CLAUDE MARLEAU
09-17-2002 19:28:35
 Re: Need info on Case Construction King Backhoe in reply to Bill b, 09-15-2002 19:54:43
HI BILL I SUSPECT STO THAT LITTLE BIT OF INFO YOUR BAC KHOE MIGHT BE A 530 CK OR IF GAZ IT WAS 540CK SINCE CONSTRUCTION KING IS NOT A BIG CLUE BECAUSE case CALLED ALL THE INDUSTRIAL LINE OR EVERY EQUIPMENT FOR CONSTRUCTION IS STAMP CONSTRUCTION KING. ANDC YOUR BAC KHOE MODEL IS MOST LIKELY A MODEL 32 AS WELL AS THE LOADER. USUALLY THEY WOULD STAMP MODEL ON SAME PLATE AS SERIAL # IF YOU FIND ANY OTHER CLUE I WILL BE HAPPY TO TRY ANDC HELP YOU.
Alice Wenzel
06-21-2006 14:11:24
 Re: Re: Need info on Case Construction King Backho in reply to JEAN CLAUDE MARLEAU, 09-17-2002 19:28:35
1976 Case Construction King Backhoe Serial # 5201493 need to know what this is worth.
Bill b
09-21-2002 05:04:09
 Re: Re: Need info on Case Construction King Backhoe in reply to JEAN CLAUDE MARLEAU, 09-17-2002 19:28:35
Just back from hunting so late in reply. the model number on the plate with the serial number is Model 42 some one has told me it is a 1967-1970 for the year but still will look for manuals thanks for the tip. bill
