Need a picture of eagle ctr link
sHan
09-15-2002 19:08:17
I have a 56 case 401 with a eagle 3 pt hitch i need to know what the center link looked like i tried a turn style link but i cant get it to work right for example ive got a flat platform that goes on a 3 pt if i level it on the ground when i pick it up it tips down and dumps things off if i level it when its raised when i let it down the back hits the ground and the end is up in the air doesent work worth a shut that way...thanks sHan
Larry
09-16-2002 06:30:52
 Re: need a picture of eagle ctr link in reply to sHan, 09-15-2002 19:08:17
third party image
Here's the picture you wanted.
sHan HEY LARRY
09-16-2002 07:56:45
 Re: Re: need a picture of eagle ctr link in reply to Larry, 09-16-2002 06:30:52
where did ya get that picture from id like to look at it closer but its to blury if i try to blow it up...thanks again sHan
Larry
09-16-2002 09:04:59
 Re: Re: Re: need a picture of eagle ctr link in reply to sHan HEY LARRY, 09-16-2002 07:56:45
It came out of a operators instruction manual for the 400 case tractor. This one came from ebay. I also got a copy from this site,which was a reprint.
Larry
09-15-2002 19:25:48
Do you have the casting that bolts on over the PTO that your top link is supposed to hook up to?
sHan
09-15-2002 19:49:04
 Re: Re: need a picture of eagle ctr link in reply to Larry, 09-15-2002 19:25:48
I have the bracket thats right under the seat.
Larry
09-15-2002 20:45:34
 Re: Re: Re: need a picture of eagle ctr link in reply to sHan, 09-15-2002 19:49:04
That's your problem then. You need to get one of those castings so you can use your eagle hitch.
sHan
09-15-2002 21:37:01
 Re: Re: Re: Re: need a picture of eagle ctr link in reply to Larry, 09-15-2002 20:45:34
castings? ya lost me on that one....
Larry
09-16-2002 05:50:19
 Re: Re: Re: Re: Re: need a picture of eagle ctr link in reply to sHan, 09-15-2002 21:37:01
I'll see if I can get a picture of one for you. Maybe even scan a picture from a manual.
