David Brown PTO
steve
09-15-2002 18:46:28
I have a David Brown 990. The PTO is not working well. The 1000 rpm works fine, but when I move the lever to put it in 540, it won't stay in. It kicks out 99% of the time. Do I need to take apart the entire PTO or is their an easier fix?
Jeb Mccranie.
09-18-2002 16:58:18
 Re: David Brown PTO in reply to steve, 09-15-2002 18:46:28
I have a case 1290 which was made by David Brown and it does the same thing. We rebuilt the clutch and it solved the problem.
Elmer
09-16-2002 04:13:00
The gears are stripped off. If you remove the cover(implematic)off the top of the pto gear box you can see what is damaged. If you have the selectamatic the top link bracket has to be removed, it is held on with six bolts. I have used parts here if you need them.
