Case VAC Serial Number
Lisa in MN
09-15-2002 13:39:36
Where do I find the serial number for an old Case Tractor. I found a number on the engine block that is VAC124-46222. But that does not seem to match what others have put on here for serial numbers. Help please!
Jennifer Clarke
03-22-2006 19:44:22
 Re: Case VAC Serial Number in reply to Lisa in MN, 09-15-2002 13:39:36
i have my vac case tractor serial number, and i am trying to find out the year and the estimated value of the tractor. i would like to know if there are any websites that i can look up to find this information...
thank you, Jennifer
augie584
09-15-2002 16:31:15
Appears it should be located on instrument panel.
Ross Provine
09-15-2002 17:22:44
 Re: Re: Case VAC Serial Number in reply to augie584, 09-15-2002 16:31:15
Augie do you know where else the serial number can be found? I bought a VA last month and the tag is long gone.
Thanks for your help
Ross
