ELMER, need DB advise- 990!
JOHN
09-15-2002 07:08:35
I have a 1972 DB 990,first, on the clutch,my clutch for the transmission works fine, but cannot get pto in gear without shutting down the tractor and starting it in gear,any advise on how to adjust? Has synchromesh trans and 2 stage clutch on the pedal. Next thing is my tach registers the hour meter , but the engine speed needle quit working, can this be fixed,or is tach junk? Thank you.
Elmer
09-15-2002 12:40:10
 Re: ELMER, need DB advise- 990! in reply to JOHN, 09-15-2002 07:08:35
Look up through the inspection hole under the clutch housing. Turn the flywheel and you will see 3 ajustment screws on the outter circumference. A 1/2 inch wrench will loosen the jam nuts. Use an allen wrench to turn the screws in and bottom them out. Then back them out exactly two turns each. Your tach is not servicable. I have new aftermarket tachs available.
ray stark
02-11-2004 15:31:16
 Re: Re: ELMER, need DB advise- 990! in reply to Elmer, 09-15-2002 12:40:10
Elmer I need price on parts for 990.
I couldn't get through to you by clicking on your name . something with my computer. I have a 990 and I need to know if you have a tach/hour meter and a drive cable for it. Also need a price on these if you have them. please email at you convienance. thanks Ray
Eddie in KY
09-16-2002 19:30:00
Elmer is exactly right on the adjustment. Use an offset box wrench and it will make it easier to loosen the jam nuts.
