Case vac
IH man
09-14-2002 15:27:54
Any suggestions on how to seal the final drive up? Its leaking oil really bad around where the brake rod enters the final drive. WE really dont wont to split the tractor if we dont have too. WE were told that you could put J B weld around the shaft where the seal rides it would make them seal. Will that work?
Tom Harrower
09-14-2002 17:12:57
 Re: case vac in reply to IH man, 09-14-2002 15:27:54
If it is the final drive oil seal it is a simple procedure to repair, I have recently done this on my '53 VAC with drum type brakes. All you have to do is remove the brake housing, there are 4 large bolts holding it on. Once you remove the housing you will have access to the seal area. If you have drum type brakes, bend the tang on the lockwasher that secures the large nut securing the brake drum, and remove the drum. The seal will be visable. Remove the seal. Case # VT-3465, or what I used , Napa part # 22448,(Chicago Rawhide and napa are the same #) and replace with a new one. The shaft on my tractor had a small wear groove in it, but the new seal seemed to take up any "slack" that was there, if the shaft has an excessive amount of wear you may need to repair the sealing area on the shaft. My tractor has not leaked a drop of oil since replacing the seal. It was fairly easy to do as well. If you need any help or pictures , E mail me ..... Tom
IH man
09-15-2002 06:30:29
 Re: Re: case vac in reply to Tom Harrower, 09-14-2002 17:12:57
I think I understand where your coming from. BUT how do I give you my E MAIL address if I come across any questions?
