SC Case clutch
Morgan
09-14-2002 11:27:09
On my 41 SC, I am trying to figure out the clutch. When it engages, it doesn't have the quick snap as my 48 SC has. I think it needs adjustment and I can't seem to figure out how to do that. It doesn't slip out when your working or anything but it just feels that it aint fully engaging.
Any help would be appreciated.
Wayne Johnson
09-17-2002 19:54:54
 Re: SC Case clutch in reply to Morgan, 09-14-2002 11:27:09
your clutch disk may need replaced, I would try adjusting first,to do this take off the plate to acess the clutch,shut off ing.,put tractor in neutral,engageclutch,look at the back of the clutch, there is a ring with a brass pin the pin must be pulled back, or pried back be careful not to break it, now rotate the collar to tighen the clutch. This may take time,cleaning, and penatrating oil. Also inspect the pressure plate for damage, and cracking.
morgan
09-18-2002 15:43:29
 Re: Re: SC Case clutch in reply to Wayne Johnson, 09-17-2002 19:54:54
Thanks, I found the pin and it was between the ring notches also the ring was all the way clockwise. I moved the ring counter-clockwise to the next notch but the pin won't come out to engage.either the pin is cut off or it is stuck in. The clutch looks to be in good shape- I can push the pin in easy enough but it won't snap out.I was wondering since the pin was in for years if it was stuck in? tractor sat a lot of years before I got it. Thanks-morgan
morgan
09-19-2002 20:19:11
 Re: Re: Re: SC Case clutch in reply to morgan, 09-18-2002 15:43:29
Got the pin pulled out!! After a little work and some cleaning with WD-40 I noticed a little hole in the middle of the step, I put a piece of baleing wire in the hole and pried on the wire with a screw driver against the access hole and the pin poped out! I cleaned the whole pin again and pushed it in and out to get all the crud loose. now it works good. THanks, morgan
