DC Overheating
John Shivers
09-13-2002 19:38:34
I have 2 DC tractors, 1951 vintage. One runs fine, the other overheats, loaded or not. Fan belt is new and snug. Radiator seems clean.
The hot one shows no circulation of water until steam starts to blow the water out, usually after about 20 minutes at idle. There is no thermostat in the system. What can stop the circulation of water in these tractors?
Where do I look?
Ken Tabor
09-15-2002 17:46:20
 Re: DC Overheating in reply to John Shivers, 09-13-2002 19:38:34
I had a D with the same problem. The bottom tank was full of caked mud as were the bottom third of the coolant tubes. Had to disassemble the whole radiator and tank system,clean the core with wire and a hack saw blade to open the passage ways. Fine since.
Carl
09-15-2002 09:25:33
I had the same problem years ago. Finally took the tanks off the radiator and rodded the tubes.
george md
09-14-2002 19:45:59
john,
you might check the impeller, could be
broken or loose on w/p shaft
george
Joe in tx
09-14-2002 07:13:47
You can back flush the water system by fixing an adaptor to the radiator drain pipe to a water hose. Hook it to your water line and turn it on. This will flush everything through the top of the radiator. I would try this first. Good luck.
Larry
09-13-2002 22:37:49
I had a 1953 DC that the water jacket was completly packed with rust around the back two cylinders. I found this after I pulled the sleeves out for a overhaul. Maybe you should pull it apart and check it out.
