Need case 504 sleeves
Travis
09-13-2002 10:27:27
Where is a good salvage yard or such, to get 6 good sleeves out of a 2290 or something with the 4 5/8 sleeves
Max
09-13-2002 19:58:00
 Re: need case 504 sleeves in reply to Travis, 09-13-2002 10:27:27
I wouldn't go with used sleeves for these were notorious for wearing in a hour glass shape. Case allowed .006 wear in the sleeve diameter from top to bottom and when needing a rebuild, they were usually beyond those specs. If you can find a low hour unit though, why not go for the 2590/4 or 4690/4 which were better pistons which were set up for intercooling and turbo? If your not looking for power another source would be from 336BD engines like found in the 850B crawlers, 880B excavators, and 780 backhoes, just need to find two though.
Larry
09-13-2002 11:46:38
What are you building? I'm just curious.
JEAN CLAUDE MARLEAU
09-15-2002 20:26:03
 Re: Re: need case 504 sleeves in reply to Larry, 09-13-2002 11:46:38
I AM FROM CANADA AND I HAVE SLEEVES FOR 504 ENGINE IF EVER INTERESTED.
JEAN CLAUDE MARLEAU
09-15-2002 20:26:00
Travis
09-14-2002 09:14:49
I am building a case 900 for pulling, I'm gonna put 504 pistons in it, which will make it a 504. I just want the sleeves though, not the pistons.
Larry
09-14-2002 09:59:11
 Re: Re: Re: need case 504 sleeves in reply to Travis, 09-14-2002 09:14:49
I kind of had the same idea. Can a guy put the direct injection heads on te older engines?
Travis
09-14-2002 13:31:41
 Re: Re: Re: Re: need case 504 sleeves in reply to Larry, 09-14-2002 09:59:11
I think you can but it takes a special block which you have to take off of a early 930 with a hand clutch, it must have the hand clutch to work. Most pullers call that block a wide block, and it excepts many different head from the later case tractors, if it is a regular 900 block it will only except the one head number.
Allan
09-13-2002 21:21:50
Case sell a rebuild kit for these motors that's as inexpensive as anyones, but that's still considerable coin.
