DC4 case heads: which is best?
Jeff
09-12-2002 19:25:46
I have a 1950 DC4 with the 5505 head. If this is the high altitude head is it made to breath better? The LP head I believe has higher compression but to get the most power wouldn't I be better off shaving the 5505 head and have the best of both worlds?
Jim M
09-12-2002 20:16:37
 Re: DC4 case heads: which is best? in reply to Jeff, 09-12-2002 19:25:46
I had a LP 6128A and a gas 5505A head side by side recently. The combustion chamber is the same length and width for both but the LP was .9" deep and the gas was 1.2" deep.
SmartAxe
09-13-2002 10:41:48
 Re: Re: DC4 case heads: which is best? in reply to Jim M, 09-12-2002 20:16:37
Just curious.. are the valves in the 6128 the same size as the valves in the 5505, or does one have larger valves than the other? I haven't seen a 6128 in person yet which is why I ask.. Thanks,
-Mark
Jim M
09-13-2002 16:31:18
 Re: Re: Re: DC4 case heads: which is best? in reply to SmartAxe, 09-13-2002 10:41:48
The valves looked the same in the 5505 and 6128
bill
09-15-2002 21:55:30
 Re: Re: Re: Re: DC4 case heads: which is best? in reply to Jim M, 09-13-2002 16:31:18
6128 head has different valves. i know one is bigger, but can't rember which one.
Wayne Johnson
09-24-2002 19:12:33
 Re: Re: Re: Re: Re: DC4 case heads: which is best? in reply to bill, 09-15-2002 21:55:30
The 6128a has a slight edge on compression. The air flow will be the same as are the valves. If you are thinking of changing a 5505 for a 6128a be sure you don't have domed 4" or tall 3 7/8" pistons as they can't enter the combustion chamber and will hit. Also the 6128a was not sold as a propane head it was just higher compression the propane tractors could have either head. Your highest compression ratio will come with the tall or domed pistons and the 5505.
