LA clutch shaft
Richard Gambrel
09-12-2002 18:46:39
On a Case LA, how do you adjust the clutch shaft gear and first reduction bevel gears to get the correct fit and correct backlash. Of course the I@T manual says use the correct Case gauge.
I have my own method for doing this but I was wondering if anyone else has their own methods for this procedure. This also has to be done on the D and S series tractors.
Thanks, Richard
Phil
09-13-2002 13:29:35
 Re: LA clutch shaft in reply to Richard Gambrell, 09-12-2002 18:46:39
I also have been wundering how to check backlash on my gears as it is apart right now awating a shift fork for the pto.
figured now is a good time to check these things.
Phil
Richard
09-13-2002 17:47:38
 Re: Re: LA clutch shaft in reply to Phil, 09-13-2002 13:29:35
Phil,
My method is to line up the short side of the gears as close as possible. Then using or removing shims try to get a very small amount of backlash leaving just enough space for gear oil to get between the gears. If anyone has a better idea, I would like to hear from them.
Richard
