Water in oil
Gregg Kuljian
09-11-2002 08:48:42
Case 430 has water in oil. I'm guessing it's the sleeves leaking, but I fixed those a couple of years ago. Are there other areas where water could get in? Head gasket, but I don't see that as the problem. I love my tractor! Has anyone fixed this problem with Barsleak or something?
Gregg
C. Amick
09-11-2002 14:01:12
 Re: Water in oil in reply to Gregg Kuljian, 09-11-2002 08:48:42
There is a block sealer product on the market. It is available at auto parts stores. I've used it in a tractor and it seems to work. You must drain the antifreeze or water and refill it with clean water and the block sealer. You must run the engine until temperature gets around 180 degrees, then drain and refill with coolant or water.
Gregg Kuljian
09-11-2002 17:54:27
 Re: Re: Water in oil in reply to C. Amick, 09-11-2002 14:01:12
Thanks! I think I ran it long enough to make "whip cream", but it seems fine. Gregg
