Identification of a Case
john nolen
09-10-2002 13:53:41
I'm trying to identify a Case tractor for a neighbor. It looks like pictures i have seen of a D series Case. it has the signature gooseneck type front tire(s) The serial number he found was up near the steering column. it is 5323573 DC. I would like to know if the DC indicates the model. Thanx for any info.
Paul f
09-10-2002 17:40:37
 Re: Identification of a Case in reply to john nolen, 09-10-2002 13:53:41
I was of the impression you subtracted 4 from the first digit of the serial # and added it to 1950 to get the year (in this case 1951) Otherwise my DC 8025000 would be a 1976 model :-)
JOhn H
09-10-2002 20:02:42
 Re: Re: Identification of a Case in reply to Paul f, 09-10-2002 17:40:37
Paul,
The procedure you are speaking of is for the last years of manufacture with the high numbers else its subtracting 4 from the first two numbers which gives John a 49. You have the high numbers.
Thanks.
Larry
09-10-2002 17:17:52
You have a 1949 Case DC. Good luck with it. I rstored mine about 2 years ago.
C. Amick
09-10-2002 14:26:35
Sounds like a DC to me. Does it have the D Series cast iron grille?
Nolen
09-11-2002 10:43:57
 Re: Re: Identification of a Case in reply to C. Amick, 09-10-2002 14:26:35
Got it! Thanx a lot guys. John
john nolen
09-10-2002 14:48:20
It has an oval opening where the radiator cap should go and at least that part of it is cast iron. I don't know if something is missing or what.
