How much does a 480C tranny wiegh?? have to change the clutch and i dont want to get crushed!!
ben
09-09-2002 20:14:36
the clutch has been slipping the last few months so i bought everything you could ever need to do a clutch , every seal, gasket, etc. so i need to drop the tranny. whats this thing weigh apporximately? its a 1979 case 480c backhoe. any help or tips appreciated. thnx!
Max
09-09-2002 20:42:04
 Re: how much does a 480C tranny wiegh?? have to change the clutch and i dont want to get crushed!! in reply to ben, 09-09-2002 20:14:36
If you're talking about the power shuttle, I used to remove and replace by hand but that was back when I could lift two 100 pound suit case weights at the same time and place on a parts counter. I would advise using a floor jack to remove and then once its out, then check to see if you can lift it. Better to be safe than to eat a chunk of casting.
ben
09-09-2002 20:46:02
 Re: Re: how much does a 480C tranny wiegh?? have to change the clutch and i dont want to get crushed!! in reply to Max, 09-09-2002 20:42:04
its the manual shuttle with manual pedal type clutch.
Max
09-10-2002 19:48:14
 Re: Re: Re: how much does a 480C tranny wiegh?? have to change the clutch and i dont want to get crushed!! in reply to ben, 09-09-2002 20:46:02
I would play it safe and use a floor jack. I would hate to tell you to do it one way and later find out that you got hurt. I forget sometimes that I was lucky in how I used to handle some of these components during removal and replacement.
