Case tractor
pete nollette
09-07-2002 11:24:49
i have a old case.need to find the location of serial no.and model.
wheat straw
09-07-2002 14:37:39
 Re: case tractor in reply to pete nollette, 09-07-2002 11:24:49
Pete,
Need a little more info. If it is a 40's or 50's look on the dash just above the steering column under the gagues. there you should find a seven digit number and a model designation. Example
VAC 5609201. If it is a 39 - 55 it will probably be a V,,VA,S,D,or LA series. Subtract 4 from the first two digits and you get the year if the first two are in the 40 or 50 range. The last two or three years the Rock Island tractors started with 60 (1954 and 55)and the Racine tractors started with 80. You have to know the year the numbers are blocked off for them.
Hope this helps. Have fun.
Wheat Straw
